MDC diff pump request output via CAN
Postby MikeD on Sat Jul 18, 2020 6:59 pm
Dear MoTeC team,
is there a chance to add diff pump request output to the CAN stream of the MDC (same mirrored signal like pin 16 - Pump relay output), maybe added to the existing diagnostic flags CAN frame?
The purpose would be to activate a pump via CAN and keep all the pump logic that you already have inside the MDC (with manual bleed override, safety timeout and so on).
I imagine the MDC's become older yet they are still used for new builds that do all the stuff via CAN nowadays.
Kind regards,
Mike
MikeD
Re: MDC diff pump request output via CAN
Postby RR213 on Sun Oct 11, 2020 5:40 pm
+1 for this.
Alternatively if the Pump Relay Output pin could be configurable as optionally low side drive for applications where an MDC is used in other than a plug and play scenario. Same for brake switch input would also be helpful.
RR213
Postby adrian on Tue Oct 13, 2020 4:52 pm
Unfortunately due to the age of the MDC we are no longer updating the functionality or software.
Return to MDC and SDC
