SDC2 Low Throttle reading issues
Postby mrsaturn7085 on Sun Mar 19, 2017 2:26 am
I am having some issues with my Low Throttle calibration on my SDC2 - going to the input tables in setup (live) and clicking 'Read' sets the following values (at zero throttle and WOT, respectively):
1.14 V
3.92 V
Afterwards, going into the live channel monitor shows that these are indeed the correct values for zero and WOT... however the TP % value translates into a range of 15-100%, omitting the bottom 0-15% range.
Anyone have any ideas, here?
mrsaturn7085
Re: SDC2 Low Throttle reading issues
Postby mrsaturn7085 on Thu Mar 23, 2017 2:17 pm
Problem solved - I've been spoiled by live-tuning on the M800. Long story short, I never hit F5 after updating the voltage values. Oddly enough, I *did* save the config file with the new voltage values and the SDC software still associates the file with the mapping loaded to the SDC2... even when there is a mismatch in some of the settings.
mrsaturn7085
Return to MDC and SDC
