SDC2 Mode select
SDC2 Mode select
Postby Robbied on Sat Dec 17, 2016 9:16 pm
Has anyone used a rotary pot to select map positions in an SDC2 (instead of the OEM thumbwheel)
Customer has asked I look into it to save space(!) on their switch panel. I don't think the map voltage thresholds are configurable so it might be tricky I guess, hence asking the forum!
Thanks,
Robbie
Robbied
Re: SDC2 Mode select
Postby br21 on Tue Dec 20, 2016 7:03 am
yes, it works fine.
I used same rotart switches for SDC modes, launch modes, etc.
br21
Postby Robbied on Wed Dec 21, 2016 8:40 pm
Got it rigged up on the bench with a 6 position rotary pot and some 1K resistors to give me a stepped voltage output.
All works well and the SDC software cycles through the modes correctly :)
Robbied
Return to MDC and SDC
