SDC2 install into V6RA with M800
I am currently in the process of installing an SDC2 into my V6RA rally car utilizing the existing DCCD wiring loom, and a gold box M800. After referencing the SDC2 manual, m8oo PnP V9 manual, Subaru MY06 manual and various othe V6 DCCD drawings I have found on the net, I am about 95% there with how I need to wire it all, however with referance to my attached drawings, I have the following questions:
Q1, Half duplex wiring, what type of circuitry do I require here to get the info from the ECU to the SDC2? ( Ihave attached a couple of circuits, however I'm unsure as to the circuitry in the SDC2)
Q2, 0V Comms does this require connection to the SDC2? if yes what pin?
Q3, Can I connect the CAN bus directly to the SDC2 as per my diagram? or do I need to connect via the onboard connector?
Q4, Is the Tacho input required for the SDC2 if I have my ground speed from the ECU over the RS232?
A couple of set up questions for experienced tuners of the SDC2, is it better to use MAP or TPS for the load table, my thoughts are that the MAP is a better representation of engine power delivery over TPS plus it is one less wire to run!
The only other connections not showing on my drawing are the display (need to bell it out to confirm wiring) and speed sensors( my car is an original RA, so no wiring or mounts in the hubs) so slip control will have to come later.
