SDC3 Map Position Indication
I'm fitting an SDC3 to a 2009 STi rally car for a customer, (combined with an M800 PnP).
The car doesn't have the original clocks. It also doesn't have the OEM diff control switches.
Looking at the SDC3 pinout, its easy enough to toggle up and down through the maps by pulling the relevant input pins to ground, using momentary switches for instance.
But does anyone have any ideas about how to indicate what diff map is selected? The unit doesn't look to have outputs to connect to LEDs, or am I wrong here? Can the diff mode number be transmitted by CAN to the M800, then up to the AIM dash, for example?
Thanks,
Robbie
Thanks,
Robbie
