Change MDC Switch On Evo X
I change MDC switch on Evo X because I change the steering wheel using oem switch part number : 8610A019
After using the new switch, after using the last mode from Tarmac - Gravel - Snow, the indicator lamp at the dashboard didn't move to first mode [Tarmac] it still remain the last mode that I'm using until I turn off the engine then the MDC mode back to first mode.
I didn't found this problem while using the original switch at the steering wheel.
Please advice, I really appreciat it
