Change MDC Switch On Evo X
Postby Loqy on Tue Sep 09, 2014 3:45 pm
I change MDC switch on Evo X because I change the steering wheel using oem switch part number : 8610A019
After using the new switch, after using the last mode from Tarmac - Gravel - Snow, the indicator lamp at the dashboard didn't move to first mode [Tarmac] it still remain the last mode that I'm using until I turn off the engine then the MDC mode back to first mode.
I didn't found this problem while using the original switch at the steering wheel.
Please advice, I really appreciat it
Loqy Siregar
Loqy
Re: Change MDC Switch On Evo X
Postby tracer on Wed Sep 02, 2015 9:14 am
Did you find the solution?
Same problem here, when connecting mdc2 to evo x gsr with acd switch on central console. It seems that a steering wheel switch is wired to pin 11, and central console button is wired to pin 21. Also steering wheel switch seems to have 2 positions up/down, with different resistors, and central console switch just inputs +12v on pin 21.
Am I right?
What's the recommended workaround?
tracer
Return to MDC and SDC
