Is MDC CAN terminated in the box?
Fri Apr 15, 2011 6:49 am
by Mazi
Cars are not at home so I can't find out...
Re: Is MDC CAN terminated in the box?
Thu May 03, 2012 5:48 pm
by OmarK
By default from factory there is no CAN termination resistor active in the MDC. But if you look at the MDC user manual you will see that a link can be soldered inside the MDC but this is not recommended as it cannot be obvious to others if the resistor is connected. So we would recommend putting a resistor on the CAN bus wires externally of the box if the MDC is one end of your CAN bus main trunk.
