SDC Base Map Subaru N10 Gravel Rally
Postby DonaldKerr on Mon Apr 12, 2010 4:54 pm
Can anyone help with a base map for a Subaru N10 gravel rally car?
DonaldKerr
Re: SDC Base Map Subaru N10 Gravel Rally
Postby DonaldKerr on Tue Apr 13, 2010 7:19 am
It would be greatly appreciated if someone could help. Would like to get something organised for this weekend.
DonaldKerr
Postby JamieA on Tue Apr 27, 2010 10:24 am
You should use the base maps provided with the diff controller, they were actually created using a gravel rally car, and are a reasonably good starting point.
After I spent some time configuring the diff controller for some drivers, what became most apparent is that although this map is a very good starting point, is wont suit everyone.
Some drivers prefer more understeer, some oversteer, so you will need to modify this start file to suit the handling characteristics that your driver wants. There is really no such thing as the perfect SDC map, as it is so specific to the driver requiremtns.
regards
Jamie
JamieA
Return to MDC and SDC
