SDC2 sensor ground for direct wheel speed input
Discussion and support for MoTeC's Mitsubishi and Subaru Diff Controllers
Postby Mattk@dentsport on Mon Sep 30, 2013 7:39 am
I am trying to discover which pin should be used for sensor ground for the magnetic wheel speed sensors on an SDC2. I have used this setup with an SDC and there is a link to join which makes a certain pin into 0V for the mag sensors. The SDC2 mentions none of this in the manual and I cannot decide where to send the second wire from the speed sensors. Thanks for any help in advance!
Mattk@dentsport
Re: SDC2 sensor ground for direct wheel speed input
Postby Dragon on Thu Oct 03, 2013 12:22 pm
I think I used A11 for sensor ground.
Dragon
Postby Mattk@dentsport on Sun Oct 06, 2013 2:36 am
Thanks! I found some notes from a previous install and we used A11 there also.
Mattk@dentsport
Return to MDC and SDC
