Nissan VQ35HR Dual intake
Files not endorsed or guaranteed by MoTeC. Use at your own risk
Postby Martin on Wed Mar 04, 2009 7:26 am
Has anybody got a startup file for this engine or some information?
Re: Nissan VQ35HR Dual intake
Postby Martin on Wed Mar 11, 2009 7:14 am
Here are some information I found.
Nobody fitted a standalone ECU to this engine before?
VQ35HR Exhaust cam retarder pinout.jpg (53.57 KiB) Viewed 15117 times
VQ35HR Exhaust cam retarder.jpg (91.83 KiB) Viewed 15112 times
Postby Stephen96 on Mon Apr 06, 2009 11:10 pm
I have the HR motor running with cam control on the inlet and exhaust. I used the Mode 55 as the basis for the setup but we are using an aftermarket flywheel with a Magnetic pickup so my settings wont help. This is the infomation supplied to us.
Nissan VQ35 Alternate Relative Sync.doc
(40 KiB) Downloaded 1691 times
For the cam control you will need to find the duty cycle where the cam position is stable and go minus 5 and plus 5
for your low and high duty cycle. When finding the cam stable position remember the exhaust cam has a polarity of 1 and count down from 100 to find the stable duty cycle.
Stephen96
Postby Martin on Tue Apr 07, 2009 6:02 am
Hi Stephen,
I have it running, Cam control works on both banks. Im also running a modified triggerwheel (mag sensor) but it is still 10-2 10-2 10-2.
IM running mode 35. (saves a digital input) I copied the OEM trigger wheel setup.....
The left inlet cam has the following patern.....single......single.....double.....double.....
The last double`s rising edge should happen right in the middle of 2 gaps with no advance on the inlet.
Im doing my second one at the moment.
If you would like to share info pm me your email address.
Thanks for your reply!
M
Return to User Posted Tune Files
