Ford YB cosworth n/a 8 injectors 12+1 M800
PostPosted: Thu May 01, 2008 1:18 pm
by motec
ECU: M800
Engine: Ford YB Cosworth Normilly Aspirated
Trigger Mode:12 tooth chopper disk and 1 tooth synk, both hall.
Fuel: AVGAS
Compression: 12.5:1
Cams: Race
Inlet: 48mm quad throttle bodies
Exhaust: Tri Y
Ignition: inductive single coil and distributer
Injection: 8 injectors Hi/Lo Bosch 803 and Bosch 363
