M130 Start File - 1994 4g63t
Files not endorsed or guaranteed by MoTeC. Use at your own risk
Postby kypreo7 on Thu Nov 03, 2016 7:01 pm
Hey guys, Just wondering if anyone had something basic i could play with and start plugging numbers in to get the car cranked over. e85 fuel, big injectors.
1994 4g63t - Evo 3 / GSR
Thanks.
kypreo7
Re: M130 Start File - 1994 4g63t
Postby Stephen Dean on Fri Nov 04, 2016 8:16 am
If you have the basics in the M1 setup correctly, the standard efficiency table should be pretty close to startable on most engines, you may need to move the efficiency point up or down a small amount, but not a lot.
Postby kypreo7 on Sat Nov 05, 2016 1:07 am
Awesome thanks mate, ill set some sensor limits nice and tight just in case. And give it a whirl! :D
kypreo7
Return to User Posted Tune Files
