4g69
Files not endorsed or guaranteed by MoTeC. Use at your own risk
4g69
Postby hornet75 on Sun Nov 09, 2014 2:40 pm
hey guys anyone have a start file or info on 4g69 im using an m48 but any ecu file will do
hornet75
Re: 4g69
Postby hornet75 on Thu Feb 05, 2015 10:53 am
gday guys need some help with a start file for a 4g69,i am using a m84 now not the m48. maybe just some help with ref sync mode the crank sensor is 36-1-2 as pictured on the left
hornet75
Re: 4g69
Postby hornet75 on Thu Feb 05, 2015 10:55 am
this is the cam sensor
hornet75
Re: 4g69
Postby AdamW on Thu Feb 05, 2015 1:59 pm
Did you try Mode 46? I know mitsi CZ3 engine is 36-2-1 with a 6 tooth cam wheel but I don't know if the cam teeth have the same pattern as yours.
Motorsport Electronics Ltd.
AdamW
Re: 4g69
Postby hornet75 on Fri Feb 06, 2015 1:28 pm
thanks for that,i inspected a cz3 at work today and it looks the same.i will give that a try
hornet75
Re: 4g69
Postby hornet75 on Tue Mar 24, 2015 11:48 am
does anyone have a cz3 colt start file?
hornet75
Return to User Posted Tune Files
