Files not endorsed or guaranteed by MoTeC. Use at your own risk
by andi m on Mon May 23, 2011 7:47 am
hi there,
can anyone help with a basic map or config for a 1.8t 20v engine, it with a m4 ecu
any help would be great thanks
andi m
by yotamhks on Mon May 23, 2011 5:43 pm
what do you need, startup settings or base map?
what is the problem? base settings or even base map wont do you no good if you are not femiliar with the ecu.
yotamhks
by andi m on Mon May 23, 2011 6:05 pm
im very familar with the ecu, its just to ease the inital start up, saves flattaning batterys and waisting time and money,
andi m
Return to User Posted Tune Files
