Posting and Using tune files
This thread is to be used by motec customers to help each other with start files for specific applications. Post only good known files, with as much detail as possible about any mods made to the car and engine from standard.
All persons using posted files do so at their own risk. MoTeC does not guarentee the integrity or correctness of any file posted here. You should only ever use these files as a starting point, your own car will still need to be tuned to suit the specifics of your engine, fuel and level of modifications.
Please use the template below as a starting point for your information about your start file.
ECU:
Engine:
Trigger Mode:
Fuel Octane:
Fuel Pressure:
Compression:
Cams:
Inlet:
Exhaust:
Ignition:
Injection:
Attach file here<-
ECU:
Engine:
Trigger Mode:
Fuel Octane:
Fuel Pressure:
Compression:
Cams:
Inlet:
Exhaust:
Ignition:
Injection:
Attach file here<-
