Posting and Using tune files
Files not endorsed or guaranteed by MoTeC. Use at your own risk
Postby JamieA on Tue Jun 17, 2008 3:59 pm
This thread is to be used by motec customers to help each other with start files for specific applications. Post only good known files, with as much detail as possible about any mods made to the car and engine from standard.
All persons using posted files do so at their own risk. MoTeC does not guarentee the integrity or correctness of any file posted here. You should only ever use these files as a starting point, your own car will still need to be tuned to suit the specifics of your engine, fuel and level of modifications.
Please use the template below as a starting point for your information about your start file.
ECU:
Engine:
Trigger Mode:
Fuel Octane:
Fuel Pressure:
Compression:
Cams:
Inlet:
Exhaust:
Ignition:
Injection:
Attach file here<-
JamieA
Re: Posting and Using tune files
Postby chana1962 on Sat Jul 16, 2011 5:09 am
I'm sing Evo 9.Here is some details:
Evo 9
OEM head with Braincrover 270/270 cams
OEM intake manifold w. OEM throttle
Wiseco pistons and rods
OEM turbo
RC 1000cc injectors
Denso racing plugs #31
Motec M800 OEM Evo 89 ECU
Please If you have any MAP files for Evo 8 and 9 email me them.I like to check my car performance with them. I want Stater Map file too.
My email : cdsalwathura@gmail.com
Hope your reply.
Regards,
Chana
chana1962
Return to User Posted Tune Files
