L98 Gen 4 VZ Holden base map
Files not endorsed or guaranteed by MoTeC. Use at your own risk
Re: L98 Gen 4 VZ Holden base map
Postby Martin on Mon Jun 08, 2009 3:47 am
I guess you have most internals modified? What sort of boost can you safely have on OEM internals?
Postby Martin on Mon Jun 08, 2009 4:02 am
Postby IJ. on Mon Jun 08, 2009 9:33 am
The "plan" is to do it all on an unopened engine and see how it all responds Martin.
People here are running 10>12psi but most are using lots of overlap on the cam to bleed off cylinder pressure, I'll use the methanol injection to counteract this with the stock cam.
IJ.
Postby IJ. on Sun Jun 14, 2009 9:52 pm
Got the start file Martin :)
You were correct it's mode #17.
I'm just about done on the mechanical's and fabrication so it's almost time to begin wiring.
IJ.
Postby Martin on Mon Jun 15, 2009 3:22 pm
Great!
Mode 23 sensors will fit on Mode 17 engines, allthough both are hall, (you will have to swap pins to get them working) still it will not work, the mode 23 sensor will not read the teeth inside. I dont think its a length issue but rather a pole diameter problem.
Cheers
M
Postby SprinterTRD on Wed Jun 17, 2009 9:14 am
The problem is one sensor is a dual hall sensor and the other is a single hall sensor.
The dual hall sensor operates with the strange looking crank disk with the offset teeth. One sensor element is used to switch the output from high to low on one set of teeth and the other sensor element is used on the other set of teeth to switch from low to high.
The single hall element sensor just needs a normal style tooth to operate.
Postby Martin on Wed Jun 17, 2009 1:29 pm
Good Info, thanks
Postby IJ. on Mon Jun 14, 2010 9:28 am
Just an update, engine fired/ran on the very first crank :D
Had an issue with a cracked transmission case late last year that set the project back some but am catching up now.
IJ.
Postby Daniel on Mon Jun 14, 2010 9:17 pm
We need pictures mate.
Danic Performance
Daniel
Postby Ellis7 on Tue Jun 03, 2014 2:01 pm
Here is a V3.50 start file with some mapping for an L76/L98 engine with DBW. Please note that your CrIP may need to be altered by 6 degrees either way as changing your cam gear, however minutely, may change the index tooth by one position.
L98 Rev 10a.e35
L98 start and basic map
(72 KiB) Downloaded 2875 times
Ellis7
Return to User Posted Tune Files
