could anyone help with config or map 1.8t golf
Files not endorsed or guaranteed by MoTeC. Use at your own risk
Postby andi m on Mon May 23, 2011 7:47 am
hi there,
can anyone help with a basic map or config for a 1.8t 20v engine, it with a m4 ecu
any help would be great thanks
andi m
Re: could anyone help with config or map 1.8t golf
Postby yotamhks on Mon May 23, 2011 5:43 pm
what do you need, startup settings or base map?
what is the problem? base settings or even base map wont do you no good if you are not femiliar with the ecu.
yotamhks
Postby andi m on Mon May 23, 2011 6:05 pm
im very familar with the ecu, its just to ease the inital start up, saves flattaning batterys and waisting time and money,
andi m
Return to User Posted Tune Files
