Engine: 1JZ-GTE 2.5L in a Soarer
Porting Work: Power Ported inlet manifold, mild ported head inlet and exhaust.
Cams: HKS 264 inlet/exhaust w/Adjustable cam gears
Injectors: Sard Low Imp 0.75ms lag time 800cc Side Feeds
Turbo: HKS T51S (650hp rated) journal bearing, Compressor 82mm exducer 62mm inducer with a TA45 turbine wheel that's around 64mm or 68mm exducer . Rear Housing a/r 0.90, Front housing a/r 0.72 .
Turbo Manifold: Generic stainless steel merge collector manifold that I have match ported - a custom split pulse merge collector manifold should see 100-200rpm increase in boost response.
Ignition: Motec CDI, wasted spark. ICE HEI 8mm leads.
Plugs: BCP 7 ES gapped to 0.813mm
Power: 382.4rwkw on a mainline dyno at 28psi, 340 rwkw at 20psi
Trans and Clutch: r154 manual using a Jim Berry 3450lbs single plate 5 puck carbotic clutch.
Tune: Tune is really rough, but makes the power, however the AFRs are in the 10.2-11.5 under boost. It should make more power with a better tune and be much more smoother whilst coming to full boost. Battery comp table is from the Denso 550cc USDM Supra as well as the current settings.
ECU Firmware: M800 2.3 . I have tried the 3.5 firmware and it has been a large contributing factor to many idle problems and cold and hot start. I downgraded to the 2.3 software and it has been running just as it should be with not one stall and no fouled plugs.
Please use at your own risk. The fuel and ignition map is not optimised - but it works!
