PDM 30
Thu Feb 25, 2016 2:39 pm
by bullet
we are using a PDM 30 for drag racing and have a M/W Pro Drag 4 ignition system to install, will one 20amp o/put be enough (MW specifies max current of 20amp and use a 25amp fuse). PDM30 spec show 20amp continuous and 115amp transient so for drag racing one o/put would be ok?
Re: PDM 30
Mon Feb 29, 2016 6:35 am
by tepid1
Is the car on 16v?
My PD4 never pulled over 18A when I had it.
Re: PDM 30
Mon Feb 29, 2016 9:04 am
If you use both pins of the output, and a larger gauge Tefzel wire for the connection, then this will be acceptable. We recommend the use of Tefzel for higher draw currents as the insulation can cope with more heat.
