PDM 30
Support for all parts of the MoTeC Website and the MoTeC Forum
PDM 30
Postby bullet on Thu Feb 25, 2016 2:39 pm
we are using a PDM 30 for drag racing and have a M/W Pro Drag 4 ignition system to install, will one 20amp o/put be enough (MW specifies max current of 20amp and use a 25amp fuse). PDM30 spec show 20amp continuous and 115amp transient so for drag racing one o/put would be ok?
bullet
Re: PDM 30
Postby tepid1 on Mon Feb 29, 2016 6:35 am
Is the car on 16v?
My PD4 never pulled over 18A when I had it.
tepid1
Re: PDM 30
Postby Stephen Dean on Mon Feb 29, 2016 9:04 am
If you use both pins of the output, and a larger gauge Tefzel wire for the connection, then this will be acceptable. We recommend the use of Tefzel for higher draw currents as the insulation can cope with more heat.
Return to MoTeC Forum and Website Support
