roving idle
Support for all parts of the MoTeC Website and the MoTeC Forum
roving idle
Postby frank mc on Mon Dec 06, 2010 9:25 am
delete
frank mc
Re: roving idle
Postby frank mc on Sun Dec 19, 2010 8:08 am
anyone got any ideas
frank mc
Re: roving idle
Postby Martin on Tue Dec 21, 2010 6:06 am
1.Are you using the idle control valve? (is it set up correctly?)
2.Is the butterfly jacked open for Anti lag?
3.Are the fuel and IGN tables acceptable at idle? (should be fairly flat, maybe IGN dropoff where you dont want it to idle)
4.Do you perhaps have overrun fuel cut enabled with the setup incorrect that will make it rev up to the cut rpm and then die down again until it gets to the recovery rpm and then rev up again?
There are many possibilities why it could hunt, we need to identify what it is that is making it hunt before we can fix it. If you make sure of the above then we could try and pinpoint it.
Return to MoTeC Forum and Website Support
