Interpreter manipulation
Postby 64hardtop on Sat Jul 26, 2008 8:37 pm
How do I change the x axis from time to distance? Also, how do I display calc'd values eg, wheel slip percentage from logged front and rear wheel speeds? This is from loged data from an M8.
64hardtop
Re: Interpreter manipulation
Postby JamieA on Mon Jul 28, 2008 8:55 pm
F9 is used to toggle between Time and Distance mode.
If you are using interpreter still, you should move over to i2, as it cost nothing to do so, will work with you existing files, has more features, and we do no longer really support interpreter...
regards
Jamie - portugal support team
JamieA
