T2 Server Network connection doesn't support hostnames
I have a telemetry setup that uses dynamic DNS to determine the IP address assigned by the Cellular Network Provider for the car.
It's possible to reach my telemetry data stream through a UDP port at LigierLMP3-68.eairlink.com, however I can't enter this in the input setup for T2 Server as it reports this is "not a valid domain name".
Well, it's valid enough for a command line "ping LigierLMP3-68.eairlink.com" to determine the IP address was 100.70.13.46
This IP address could change when the car is power cycled (like each day). I don't mind power cycling T2 Server, but I would like it to find the new IP address when it has changed.
Is there some format (URL?) required to get T2 Server to look up the IP using DNS?
Thanks!
Thanks!
