Telemetry Monitor - Can't access Properties via Right-Click
I have Telemetry Monitor 2.3.2087.0 installed on several machines running Windows 7 Pro SP1, and all of them seem to function normally, except one.
The one in question loads Telemetry Monitor properly and receives data, but the Properties window will not pop up when right-clicking any item in the worksheets. The Windows cursor is always a resize double-arrow when hovering over anything in the sheet.
Because of this, I can't change any of the graph or gauge properties, or change existing track maps.
I can however add new items through the top pull-down menu.
The worksheets can be copied to the other machines, edited, copied back, and they function normally.
I have uninstalled TM, and reinstalled it - no change.
Anyone seen this before, or have a fix?
Thanks.
Thanks.
