I've connected the coil input (through a filter and square wave reconstruction circuit) of a 4 cycle V8 engine with a coil on plug ignition to one of the digital inputs on an ADL3. This generates one pulse per every other engine revolution. When I attempt to calibrate the input in Dash Manager, I need to set it to 0.5 pulses per revolution. This isn't possible to do. The minimum is 1 pulse per revolution. This would be fine for an engine running waste spark, but it doesn't work for an engine with a COP ignition. Am I missing something here?
The only work around I've determined is to choose Custom Calibration, select Count and put two data points in the graph. One at (0,0) and the second at (5,000, 10,000), (Count, rpm). I have yet to test this but I think it should work. Is this the only way to deal with this issue?
