i2 Problem
i2 Problem
Postby IDP on Thu Aug 14, 2008 12:16 am
I have a problem with i2 when using overlayed laps with an overlay offset.
If when using 2 laps and an offset overlay you filter a channel (any channel) the distance of the overlay lap changes.
This only occurs if the laps are "stretched to track distance"
It also only occurs if the overlayed laps are distance offset.
It appears that after filtering a channel the lap stretching is no longer applied to the overlay lap.
If you then open the corrected speed and distance page and go to the corrected distance tab, change nothing but click ok the overlay lap is then stretched to track distance again.
I am using the latest release of i2
IDP
Re: i2 Problem
Postby JamieA on Thu Aug 14, 2008 10:23 am
Ok, have seen the problem. Added the issue to the problem tracking system...
thanks.
-Jamie
JamieA
