Counter Function?
Thu Feb 04, 2010 12:47 pm
by paul.livanos
Doing some brake testing. Have already setup a math channel so that when brake pedal position is greater than x%, "brake status" is '0' (off) or '1' (on).
What I would now like is a counter for brake status. Is this possible?
Thanks,
Paul
Re: Counter Function?
Sun Feb 07, 2010 7:16 am
by Fermin
I dont know if I understand you, but maybe I can help you.
If you seek a expression that say you the number o times that the brake pedal pos is greater than x% by each lap, for example, brake pedal pos greater than 50% by each lap, this is a way (i2 Pro V1.05.0013):
A: 'Brake Pedal Pos' [%] > 50
B: time_shift('A',0.001) [Rate:1000Hz]
C: max('A' - 'B',0)
D: integrate('C') [Rate:1000Hz]
NÂș of time Brake Pedal Pos greater than 50%: (stat_max('D', 'Gear' < 100,range_change ("Outings:Laps")) - stat_min('D', 'Gear' < 100,range_change ("Outings:Laps"))) * 1000 [Rate:1000Hz]
Mon Feb 08, 2010 12:35 pm
by paul.livanos
Yes that seems to work.
Thanks for your help.
