Corrected Speed problem
I would like to get the corrected speed and distance generated from a logfile coming from an ECU.
The problem is that you cannot select.."Ground speed Left" or "ground speed right" or the driven wheelspeeds.
under tools>corrected speed and distance there is "groundspeed" and also "drive speed" but not the individual left and right channels. You are also not able to enter those channels when you try to add a channel...
MoTeC.Interpreter.Std (1.0.5.12)
M
M
