show aim boost
Thu Sep 24, 2009 7:13 pm
by fetzi
hello,
how can i show aim boost (from the map) to compare with the logged manifold pressure?
i need to compare to adjust the pid-parameters of boost control.
thx.
regards
fetzi
Re: show aim boost
Thu Sep 24, 2009 7:25 pm
by IJ.
Data Logging>Boost>Boost Aim.
Re: show aim boost
Thu Sep 24, 2009 9:55 pm
by fetzi
i did this but i cannot find it in the logging program (i2standard).
regards
fetzi
Re: show aim boost
Thu Sep 24, 2009 10:27 pm
by IJ.
Sorry can't find a log file where I've had it enabled to confirm....
Re: show aim boost
Fri Sep 25, 2009 10:10 am
by RossB
Fetzi,
You need to make sure that you are logging the channel called "Boost Aim". It should then appear in your Channel list in the data log file. Also, if you are using an M800 make sure that you have not exceeded the maximum number of channels that can be logged (64 Channels). Any channels added to the logging setup in addition to the 64 channels will not be logged.
