Export Data Option
Export Data Option
Postby paul.livanos on Tue Sep 15, 2009 11:24 am
I'd like to know if there is a way to export the "cursor values"?
i.e. I'd only like to export (to .csv) the single value for each channel when you place the cursor line over them.
cheers,
paul
paul.livanos
Re: Export Data Option
Postby RossB on Fri Sep 25, 2009 10:25 am
You can't export a curser value but you can zoom in to a single data point and export the visable data. BUT if you press "S" so that you can see each sample point then zoom in on that point and do an export from there you will be able to export the data from that single point. If you have channels logged at different rates the sample point you pick for one channel may not have data from channels which have been logged at lower frequency so these channels will have a zero value.
