Distance/time
Thu Jun 04, 2009 8:38 am
by Monstrobolaxa
Well...changing the X-axis to distance gives me a N/A!
Corrected speed is also N/A!
What to do?
Re: Distance/time
Thu Jun 04, 2009 10:43 am
by DarrenR
You need to change the settings in Tools|Corrected Speed and Distance to suit your log file so the 'Corrected Distance' channel reads something. This is the distance channel used as the lap distance on the graph.
By default the Corrected Distance is calculated from Corrected Speed, and Corrected Speed comes from one of a common speed channel listed in the corrected speed setup, so usually you will have a distance channel, but not always.
Re: Distance/time
Fri Jun 05, 2009 10:49 pm
by Monstrobolaxa
Well I've been in the corr.speed toolbox and put in for it to "Use the first available from:" and put in ground speed and ground speed left, as these are the only speed channels available.
Ground speed and ground speed left are showing properlly on the graph...but Corr.Speed is shown as N/A.
Corr.Speed is enabled...what now?
Re: Distance/time
Fri Jun 05, 2009 10:55 pm
by Monstrobolaxa
Another quick question...the "Fuel Used Ecu", in which unit is it showing? kg or l?
And how accurate is it? It goes directly to the engine mapping so I'd thing it should be close enough.
Re: Distance/time
Fri Jun 05, 2009 11:45 pm
by IJ.
Took a bit of tweaking but I got my fuel used to +- .5 litre on a 115L tank.
Re: Distance/time
Sat Jun 06, 2009 7:10 am
by Monstrobolaxa
What tweaking?
I usually don't use litres as a unit as it is temperature dependent. I usually use kg.
Re: Distance/time
Sat Jun 06, 2009 10:37 am
by IJ.
Just had to adjust the "fuel used cal" a little to 0 in on the actual fuel used, once done it's perfect
Told the SDL to remind me when xx fuel is left and again at x fuel so no need for a "gauge" .
Re: Distance/time
Mon Jun 15, 2009 3:00 am
by Monstrobolaxa
Re: Distance/time
Mon Jun 15, 2009 5:21 am
by IDP
Are your ground speed channels generated by the ECU?
If they are They'll be unitless.
You'll need to use the channel mappings section in tools to give the channels a KMH unit.
Re: Distance/time
Mon Jun 15, 2009 9:31 am
by Monstrobolaxa
working...thank you very much guys. I owe you a few beers!
