Target Lambda in I2
Target Lambda in I2
Postby Iggsy on Sat May 03, 2025 5:13 pm
Is it possible to have the target lambda as a function of throttle position and RPM in the i2 software that I can use to compare against the actual logged lambda value?
Iggsy
Re: Target Lambda in I2
Postby David Ferguson on Sat May 03, 2025 11:50 pm
Is there a reason you don't just log the target lambda channel?
What device is creating the log file?
If it's a dash, you could set up a 3D table to generate this channel if you aren't getting it from the ECU.
Postby Iggsy on Sun May 04, 2025 8:40 am
Hello David.
I have an older ecu (M48) in open loop. I don’t think it’s possible to log the target channel on the m48.
I have AIM dashes.
Regards.
Iggsy
Postby Sean on Sun May 11, 2025 3:53 pm
It can be done in i2 Pro (but not in i2 Standard). In the maths window, go to create a 3d table, I'd think linear interpolation would work best. Screen shot below of a rough one I just tried.
3d lambda table sample.jpg (97.07 KiB) Viewed 1344 times
Sean
