using a xml via a plugin
PostPosted: Sat Mar 15, 2025 2:16 am
by steven.casaer
in order to protect my calculations, I would like to implement my xml files via plugin. I have generated the C# code for the xml file, but i don't succeed in creating a dll that is importing into the math library. I have an i2pro and a API licence. Can someone supply a pdf in the style of the "creating_an_i2_math_function" pdf elsewhere on the forum?
Re: using a xml via a plugin
PostPosted: Wed Mar 19, 2025 2:56 pm
by adrian
Below are the documents on creating functions and plugins for i2. They are very old documents so there might be some slight discrepancies with the current version of i2 but the basic functionality hasn't changed.
PostPosted: Fri Apr 25, 2025 2:07 am
by steven.casaer
hi Adrian,
thanks for that. I will see where I get and keep you informed!
