using a xml via a plugin
Postby steven.casaer on Sat Mar 15, 2025 2:16 am
in order to protect my calculations, I would like to implement my xml files via plugin. I have generated the C# code for the xml file, but i don't succeed in creating a dll that is importing into the math library. I have an i2pro and a API licence. Can someone supply a pdf in the style of the "creating_an_i2_math_function" pdf elsewhere on the forum?
steven.casaer
Re: using a xml via a plugin
Postby adrian on Wed Mar 19, 2025 2:56 pm
Below are the documents on creating functions and plugins for i2. They are very old documents so there might be some slight discrepancies with the current version of i2 but the basic functionality hasn't changed.
DTN0009 Creating an i2 Math Plugin.pdf
(100.55 KiB) Downloaded 506 times
DTN0008_Creating_an_i2_Math_Function.pdf
(1.03 MiB) Downloaded 622 times
Postby steven.casaer on Fri Apr 25, 2025 2:07 am
hi Adrian,
thanks for that. I will see where I get and keep you informed!
steven.casaer
