2D Table generated from Setup Sheet Channels Matching
Postby motecuser on Tue Dec 10, 2024 7:36 pm
Is it possible in MoTeC to create a 2D table entirely using values from the Setup Sheet?
When using the feature "Generate from Setup Sheet Channels Matching" to create a 2D table in math channels, I can successfully fetch the Y values for the 2D table based on the channel names. However, I cannot fetch the X values.
Even if I manually predefine the X values before ticking the checkbox, they reset to 0 once the box is ticked.
Is it possible to also fetch the X values from the Setup Sheet?
motecuser
