No Drag Project
No Drag Project
Postby M4 Ed on Wed Jul 23, 2008 4:24 am
I cannot access Drag Project in I2. I emptied all my runs and downloaded the new version but still can't get in Drag Project. I can get in the other projects and up until today I had no problems with Drag. Any help would be appreciated.
Thanks Ed
M4 Ed
Re: No Drag Project
Postby JamieA on Wed Jul 23, 2008 10:54 am
there are sometimes occasions when a project gets corrupted, and you can not open it any more. The most common reason for this is when the pc crashes or has a problem when you are working in a specific project.
There are a few ways to repair the project, but if you have nothing special in the project, the easiest fix for this is to delete the project from the drive. Next time you start up i2, it will build you a new project, and this should fix the problem.
If you are in i2 Pro, the projects are stored in
my documents\motec projects
In i2 Standard, the projects are stored in
<User Name>\AppData\Roaming\MoTeC\Standard Projects\
Just delete the drag project folder, and it will build a new one for you next time you open the drag project.
Jamie
JamieA
Re: No Drag Project
Postby M4 Ed on Mon Aug 04, 2008 12:27 am
Thanks Jamie,
I saved the old Drag Project in a separate file and after Motec rebuilt the project I was able to go get my math and project layout.
Ed
M4 Ed
Re: No Drag Project
Postby 2jzmk3 on Mon Nov 10, 2008 11:09 am
this helped me out as well, my computer froze and wouldnt let me get into the drag project..
thanks.
2jzmk3
