Corrected Distance Incorrect on Pit Lap
I'm currently running into some issues using i2 Pro 1.1.5.0085 when it comes to the `Corr Lap Dist` channel.
On normal laps it tracks the logged `LapDist` channel properly, and when I use the `Corr Speed` channel to generate it, the results are almost satisfactory. A normal lap will have the `Corr Lap Dist` and `LapDist` be exactly the same, as is expected when they are set up like [1].
A normal lap is shown in [2], with the two channels tracking the same value, and the Ground Speed being almost the same as the derivative of the distance channels (there is some difference due to different lines, etc.)
Then we can see the problem if there is a pit stop. In [3], there is a graph on the time mode. In [2] the Corr Lap Dist was a relatively wavy line, changing with the speed of the vehicle as it covered more or less ground, but here we see that the Corr Lap Dist channel is simply a line from 0 to ~5687, completely different from the `Lap Dist` channel. On the distance graph in [4] they don't match up either because of the miscalculation for the Corr Lap Dist channel.
Here's an album of the screenshots in case the image embeds don't work. I can also upload an export of a few laps if that would help debug this, as well.
https://imgur.com/a/OQ6FZfQ
[1]:
[2]:
[3]:
[4]:
[1]:
[2]:
[3]:
[4]:
