Setting start/finish line to format laps
What I am trying to do is have laps formatted correctly from start/finish line after downloading when opening them in i2 without having to input the start/finish lat-long GPS every session every motorcycle. I am using an M130 with firmware very similar to 2009 Yamaha R1, and an AIM Solo DL-2 importing gps over the can bus.
We are flat track oval racing and there is no crossover that can confuse the beacon with overlap.
After downloading data I have been formatting laps from the cursor, generating the track, finding start finish on track, then resetting the laps manually by restoring the laps and inputting the GPS I worked out for start finish. Then I generate the track again and start/finish is correct. Every following session I generate laps using the same coordinates I noted from the first session.
I tried putting the start/finish GPS coordinates in the package under Lap>GPS>Beacon 1. When I generate laps in i2 it still sets the start/finish somewhere else, I assume where the cursor is.
Does it have something to do with "'current data source" vs "selected data source" under "generate laps using GPS data?
None of the tracks we use are in the "from venue" database.
Another question, in i2 standard or pro I can't get "control A" to close all the open log files?
Thanks in advance!
Thanks in advance!
