brake bias setting
PostPosted: Tue Feb 08, 2022 7:41 pm
by andy
I wonder how the brake bias setting was set up.
I wonder why the graph came out like this.
brake bias.jpg (390.16 KiB) Viewed 3798 times
'Brake Pres Front' [bar] / ('Brake Pres Front' [bar] + 'Brake Pres Rear' [bar] )
I wonder if you can calculate it only when the pressure is 1 or higher.
I wonder if this is the right setting.
Re: brake bias setting
PostPosted: Wed Feb 09, 2022 3:28 am
Here is the Dynamic Brake Bias math setup that I use:
Brake Bias w-Invalid().JPG (107.77 KiB) Viewed 3782 times
Notice I use the choose function to check for minimal pressure on both channels, and the invalid() function to say the channel is invalid with the current pressure values.
