Converting the logged data image
Sun Oct 31, 2021 6:23 pm
by EngThejoker
i have an inquiry about Converting the logged data image , i did retrieve the logged data from motec m150 when i convert it as a retrieve steps it work directly in i2 , but later on when i want to re-view the logged data i cant open it agin in i2 cus the logged data file is (.m1dli) and the i2 read (.ld) , so how can i convert the (.m1dli) file to re-view it in i2 ???
thnx alot for your time ...
Re: Converting the logged data image
Mon Nov 01, 2021 9:17 am
by Stephen Dean
Once the file has been converted to a .ld files in M1 Tune you should not need to redo the conversion to open the log file again.
The default location for the converted log file to be stored in is C:\MoTeC\Logged Data. Can you have a look in this directory to see if the data is there (i2 should also have this as the default directory when you open a new log file in i2).
Thu Nov 04, 2021 3:38 pm
by EngThejoker
hi SDean ,
when i normaly retrieve the logged data i change the file location , and when i go to C:\MoTeC\Logged Data , i only find the data which i got from gold box only , but the data from M1 i cant find it in C:\MoTeC\Logged Data .!!
Thu Nov 04, 2021 4:07 pm
by adrian
When retrieving logging from the M1, when you get to the window to fill out the details for the log file, the logging directory is specified at the bottom.
