Math for approximate lean angle for motorcycle
Postby Shuma- gorath on Thu Sep 30, 2021 9:23 am
Hi, does anybody have a Math channel that give a good approximate lean angle when using a Bosch m5.10 imu. I know it can be used to get lean angle as it is the same sensor that most of the major motorcycle manufacturers are using but just don't know how to configure it to do so. Thanks for the help.
Shuma- gorath
Re: Math for approximate lean angle for motorcycle
Postby adrian on Thu Sep 30, 2021 10:23 am
It is no simple task to calculate lean angle, have a look at this thread:
https://www.motec.com.au/forum/viewtopic.php?f=26&t=3974
David links to a good paper that will get you started.
Postby Shuma- gorath on Thu Sep 30, 2021 10:55 am
Thanks for the info but the uploaded link is on that page is not working anymore.
Shuma- gorath
Postby David Ferguson on Thu Sep 30, 2021 11:09 am
Here is the updated link. You should visit the motorcycle research section on that website, they have more content you may be interested in.
https://www.kineticorp.com/wp-content/u ... 1422-1.pdf
Postby Shuma- gorath on Thu Sep 30, 2021 11:22 am
Awesome thanks I'll take a look.
Shuma- gorath
