Integration of external CSV on .Id log file
Hi all,
i'm a newbie and what i'm trying to understand is "if it is possible" to add custom parameters to the standard set of parameters that are tracked using software such as Assetto Corsa Competizione.
I have Assetto Corsa Competizione and i installed the Motec i2 pro. After my session i can correctly see the telemetry. What i would like to do is to insert "additional" parameters to the standard telemetry that is tracked: basically some additional values / tags that i produce and have tracked on an external CSV file.
Is it possible somehow to integrate the .Id / .Idx log files that are produced with my personal CSV file in order to produce a new .Id / .Idx log file that can be opened and analyzed later on?
Thanks for your help and suggestions
Stefano
Stefano
