Integration of external CSV on .Id log file
Postby stefanodurso on Mon Aug 09, 2021 9:20 pm
Hi all,
i'm a newbie and what i'm trying to understand is "if it is possible" to add custom parameters to the standard set of parameters that are tracked using software such as Assetto Corsa Competizione.
I have Assetto Corsa Competizione and i installed the Motec i2 pro. After my session i can correctly see the telemetry. What i would like to do is to insert "additional" parameters to the standard telemetry that is tracked: basically some additional values / tags that i produce and have tracked on an external CSV file.
Is it possible somehow to integrate the .Id / .Idx log files that are produced with my personal CSV file in order to produce a new .Id / .Idx log file that can be opened and analyzed later on?
Thanks for your help and suggestions
Stefano
stefanodurso
Re: Integration of external CSV on .Id log file
Postby adrian on Tue Aug 10, 2021 12:03 pm
It really depends on what data/parameters you are trying to bring into i2. If they simple things related to the setup of the vehicle then you could look at using a setup sheet.
If it is actual data points from a run then i2 has a csv import feature. This feature requires a yearly licence, you can speak to a MoTeC Dealer (motec.com.au/dealers) for pricing information if you are interested.
Postby stefanodurso on Tue Aug 10, 2021 3:31 pm
Thanks Adrian, i’ll get in touch with the dealer!
stefanodurso
