Motorcycle engine braking
Thu May 13, 2021 7:32 pm
by SP121
This may seem like quite a simple question but I was wondering what is the best way people use to see how an engine is pushing into corners through i2 data logs so that engine braking adjustments can be made effectively. Has anyone any tips or advice?
Re: Motorcycle engine braking
Fri May 14, 2021 12:57 pm
First, I would capture front and rear wheel speeds, with a fairly high tooth count (say 18 - 36 teeth). Then I could compare wheel speeds, after calibrating both using high-speed cruising (not accelerating or braking) and GPS.
Fri May 14, 2021 5:26 pm
by SP121
Thanks for the reply David. The rules for 600s prohibit the use of a front wheel sensor.
Sun May 16, 2021 3:14 am
Then, I would install them just for testing.
Sat May 22, 2021 12:17 am
by AlanB
Diagnosing too much engine braking is quite straightforward, all you need to do is compare front wheel speed (or GPS Speed if you don't have a front wheel speed sensor) to rear wheel speed. If the rear speed is more than 10km/h below the front then the bike is probably "backing in", so will require some additional air flow through the engine (via DBW, stepper motor or air bleed valve).
Too little engine braking, where the bike is "pushing" into a corner, is harder to see on the data as the front and rear wheel speeds will be pretty much the same and this is in itself does not indicate that it is pushing. You really have to go by rider feedback and make some big changes in the area they are struggling until you start to induce some "backing-in".
When adjusting engine braking, always make sure you check the rear suspension stroke at the same time, as there is little point in adjusting the engine braking when the rear wheel is off the ground. This situation would require some chassis/suspension changes to rectify.
