Edit Idx File
Edit Idx File
Postby casaroli on Thu Feb 06, 2020 4:35 am
Hi All,
I would like to export the lap times of an logdata into text file.
My license don't have the API function. Is it still possible to act in some way?
I saw that when a log file is opened a *.idx file is created with the following information:
Total Laps
Fastest Time
Fastest Lap
Is it possible to edit the output of this file?
Thank you
casaroli
Re: Edit Idx File
Postby adrian on Mon Feb 17, 2020 5:09 pm
If you create a Time Report, right click on the report and select export. You can then export it to csv or just to the clipboard to paste into a txt file.
The .ldx file stores some basic information mostly about changes made to the .ld file. So for example if you add a manual beacon to the log file the information is stored in the .ldx file, not the .ld file. This means that the original log file is never changed, it is always as logged by the device.
Users browsing this forum: Bing [Bot] and 11 guests
