I2 Pro Visualization
Postby casaroli on Thu Feb 06, 2020 4:29 am
Hello to all,
I have some questions for you.
I would like to align the zero of all channels in the lower part of the window. When I overlap groups the zero of some channels results in a higher position than others. Is there any particular setting?
I would like to remove the gray background in the laps that are not the selected lap in order to always have the black background even after two laps. Is it possible?
I would like highlight the channel when higher than specific value.. Is it possible?
2020-02-05 18_22_49-Greenshot.jpg (241.29 KiB) Viewed 7787 times
2020-02-05 18_51_38-Greenshot.jpg (43.49 KiB) Viewed 7781 times
casaroli
Re: I2 Pro Visualization
Postby adrian on Mon Feb 17, 2020 4:58 pm
When you overlap groups in a T/D graph the axles values used are for the selected channel and then all the other channels are scaled from min to max, bottom to top.
You can change the scaling by clicking and dragging the bars on the right.
i2 - 01.png (601.73 KiB) Viewed 7657 times
Or you can adjust the values in the properties window.
i2 - 02.png (176.39 KiB) Viewed 7657 times
To change the grey background go to Tools>Options>Colours and change "Data area range background" to black.
At the moment highlighting the channel based on a condition isn't possible.
Users browsing this forum: No registered users and 32 guests
