Re: Importing CSV's
Tue Apr 21, 2020 10:15 pm
by greenamex2
Thanks David. Tried it but it doesn't seems to be picking up the laps...any idea what I have done wrong?
This is the first few lines of the CSV file. I had to add the beacon line as it wasn't in the example I cribbed -
"Driver","Denis Bassom",,,"Engine ID","4A-GE"
"Device","PI_CL"
"Comment","Qual",,,"Session","1"
"Log Date","03/06/2012",,,"Origin Time","0.000","s"
"Log Time","0:00:01 AM",,,"Start Time","0.000","s"
"Sample Rate","10","Hz",,"End Time","529.6","s"
"Duration","529.6","s",,"Start Distance","0","m"
"Range","entire outing",,,"End Distance","9873.42","m"
"Beacon Markers","156.295 69.125 69.226 66.130 167.754"
"Time","Gear","Engine RPM","Ground Speed","G Force Lat","Eng Oil Pres","Engine Temp","Eng Oil Temp","Fuel Pres","Bat Volts ADL","Lap Distance","Throttle Pos","Damper Pos FL","Damper Pos FR","Damper Pos RL","Damper Pos RR","Damper Velocity FL","Damper Velocity FR","Damper Velocity RL","Damper Velocity RR","Brake Pres Front","Brake Pres Rear","Brake Bias Setting","Exhaust Temp Bank 1","Exhaust Temp Bank 2","Steered Angle","Fuel Tank Level","Avg Fuel Econ","Fuel Used","Laps Remaining","Beacon","Lap Time","Corr Dist"
"s","none","rpm","km/h","G","kPa","C","C","kPa","V","m","%","mm","mm","mm","mm","mm/s","mm/s","mm/s","mm/s","kPa","kPa","%","C","C","deg","l","m/l","l","none","none","s","m"
"0","1","1112","0","0.17","102","67.9","24.9","357","10.73","0","77.9","0","0","0","0","-3600","-3600","-4800","-6100","0","0","0","0","0","-46.6","0","0","0","0","0","0","0"
"0.1","1","1579","0","0.17","102","67.9","24.9","357","10.73","0","88.4","0","0","0","0","-1200","4800","1200","3600","0","0","0","0","0","-46.6","0","0","0","0","0","0","0"
"0.2","1","2071","0","0.02","189","67.9","24.9","365","11.07","0","87.9","0","0","0","0","-6100","-4800","-4800","-6100","0","0","0","0","0","-46.6","0","0","0","0","0","0","0"
"0.3","1","2575","0","0.02","189","67.9","24.9","365","11.07","0","62.9","0","0","0","0","-2400","-2400","-4800","-3600","0","0","0","0","0","-46.6","0","0","0","0","0","0","0"
"0.4","1","2806","0","0","326","67.9","24.9","358","11.29","0","30.4","0","0","0","0","-2400","-3600","-3600","-3600","0","0","0","0","0","-46.6","0","0","0","0","0","0","0"
"0.5","1","2442","0","0","326","67.9","24.9","358","11.29","0","0.4","0","0","0","0","4800","3600","3600","2400","0","0","0","0","0","-46.6","0","0","0","0","0","0","0"
Oh, and if you want a decent line editor try "Notepad++". Lots of great features. For example, I currently have over 20 CSV's open at once and can do text replace across all of them simultaneously.
