Corrected speed and distance wont save
Postby Trevan on Sat Jan 12, 2019 8:22 am
I just updated to i2 standard 64bit to the latest version 1.1.4.422. After the update any settings modified under tools --> corrected speed and gps are not saving when i2 is closed and re opened.
Has anyone else had this happen or worked it out?
Cheers,
Trevan
Trevan
Re: Corrected speed and distance wont save
Postby adrian on Mon Jan 14, 2019 8:57 am
This is a known issue, we are currently testing a version of i2 that has a fix for this in it.
Postby Trevan on Tue Jan 15, 2019 6:55 pm
Thanks Adrian, ill keep an eye out for the update to come through.
Trevan
Postby terryo on Sat Feb 29, 2020 9:58 pm
did this get sorted??. ive downloaded the latest version and seem to be having the same problem
terryo
Postby David Ferguson on Sun Mar 01, 2020 8:30 am
Did you try saving your workspace?
Postby adrian on Mon Mar 02, 2020 9:41 am
If you download the current beta from here this issue has been fixed.
Postby Trevan on Fri Nov 12, 2021 8:57 pm
I am probably going mad but it seems like this is happening again in standard 1.1.4.690 (64bit).
After setting corrected speed and saving the workspace it resets when i2 is closed and reopened.
Anyone else experiencing the same thing?
Trevan
Postby Sean on Wed Sep 14, 2022 8:19 pm
Late to the party here, but getting the same thing, when trying to change and save the gps speed input channel name. Latest beta version installed, which didn't help. Any chance of a fix for this please?
I have just tested, this functions correctly in i2 pro, only std is broken.
Sean
